1.5mm to 15mm thick soft wood, laminated boards, plywood especially suited to tight curved corners.
Bosch
Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood
| Jigsaw Blade Length | 51 mm |
| Max Cutting Depth | 15 mm |
| Model | T101AO |
| Blade Type | HCS, Ground and Taper Ground |
| Jigsaw Blade Type | Tight Curves |
| Pack Quantity | 5 |
| Tooth Pitch \ tpi | 1.40 mm \ 18 tpi |
| Blade Type | HCS |
| Pack Quantity | 5 |
| Model | T101AO (Pkt 5) |
| Quantity | 5 |
| Jigsaw Cutting Depth [Cat] | 1.5-15 mm |
| EAN Barcode | 3165140006798 |
