5 - 15mm, tight curves in wood laminates, clean precise cutting on both sides of the laminate.
Bosch
Bosch T101AOF Jigsaw Blades Special Laminate (Pkt 3)
| Jigsaw Blade Length | 82 mm |
| Max Cutting Depth | 15 mm |
| Model | T101AOF |
| Blade Type | Bi-metal, Ground and Taper Ground |
| Jigsaw Blade Type | Tight Curves |
| Pack Quantity | 3 |
| Tooth Pitch \ tpi | 1.40 mm \ 18 tpi |
| Model | T101AOF (Pkt 3) |
| Quantity | 3 |
| Jigsaw Blade Type | |
| Jigsaw Cutting Depth [Cat] | 1.5-15 mm |
| EAN Barcode | 3165140393423 |
