Hard and soft wood, plywood and chipboard up to 40mm. Reversed down cutting teeth for splinter-free cutting in veneered or coated boards.
Bosch
Bosch T101BR Jigsaw Blades Reverse Cutting For Wood
| Jigsaw Blade Length | 74 mm |
| Max Cutting Depth | 40 mm |
| Model | T101BR |
| Blade Type | HCS, Ground and Taper Ground |
| Jigsaw Blade Type | Reverse Cutting |
| Tooth Pitch \ tpi | 2.54 mm \ 10 tpi |
| Pack Quantity | 5 |
| Model | T101BR (Pkt 5) |
| Quantity | 5 |
| Jigsaw Cutting Depth [Cat] | 3-30 mm |
| EAN Barcode | 3165140012454 |
