hardwood, softwood and chipboard. The plunge cutting tip of the progressor blade allows you to achieve accurate splinter-free clean cuts. The tooth geometry of the blade features a progressively increasing tooth pitch which allows you use on a variety of materials with a range of densities. Bi-metal, fully hardened high-speed steel tooth strip and highly elastic carbon steel body for cutting hard materials.
Jigsaw Blade Length 90 mm
Max Cutting Depth 25 mm
Model T234X
Blade Type HCS, Ground
Jigsaw Blade Type Fast Cutting
Pack Quantity 5
Tooth Pitch \ tpi 2.0 mm - 3.0 mm \ 12.5 - 8 tpi
Model T234X (Pkt 5)
Quantity 5
Jigsaw Cutting Depth [Cat] 3-65 mm
EAN Barcode 3165140169509
