These hand sanding blocks are long lasting and washable. Intended for use on wood or paint, they are also suitable for sanding varnish or fillers. Ideal for use on flat surfaces and edges, the foam core makes them very easy to handle. Unlike run of the mill foam sanding blocks these are conveniently colour coded for easy recognition. The three blocks cover preparation, intermediate and finish sanding. The square corners make the particularly effective for sanding rebates. The grades are medium, grit equivalent 180-240, fine, grit equivalent 220-320 and extra fine grit equivalent 360-500. Each block measures 69 x 97 x 26mm.
Overall L x W x H 69 mm x 97 mm x 26 mm
Abrasive Grit Mixed
Pack Quantity 3
EAN Barcode 3165140873444
