Bosch PRO GBH 18V-22 X Cordless Rotary Hammer with ONECHUCK is a powerful and versatile drilling solution designed for professional users who need the flexibility to work across multiple materials. Combining strong rotary hammer performance with Bosch's innovative ONECHUCK system, it accepts SDS-plus, cylindrical and hex drill bits in a single chuck, reducing the need to switch tools between tasks.
Delivering 2.0J of impact energy, a no-load speed of up to 1,050rpm and an impact rate of up to 4,675bpm, the GBH 18V-22 X is ideal for hammer drilling and chiselling in concrete and masonry, as well as drilling in wood and steel. It offers a hammer drilling capacity of 4-22mm in concrete, with an optimum working range of 6-12mm. Its brushless motor with constant speed technology maintains power output under load, helping to maximise productivity and deliver more holes per charge.
Designed with user comfort and safety in mind, the GBH 18V-22 X features KickBack Control to help protect against sudden tool rotation if the bit jams, while Vibration Control reduces fatigue during extended use. The tool is also compatible with Bosch Auto Power GDE 18V-12 and GDE 12 dust extraction attachments, helping to create a cleaner, healthier working environment.
Bosch Professional tools are engineered for demanding trade and site use, delivering the durability, performance and innovation professionals rely on every day.
Ideal for builders, electricians, plumbers, installers and maintenance professionals, the GBH 18V-22 X is a versatile rotary hammer for drilling, fixing and light chiselling applications.
Body only, not supplied with battery or charger.
Part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
Supplied with auxiliary handle and depth gauge.
Battery Voltage 18 V
Rating Trade/Professional
Battery Type Li-ion
Corded or Cordless Cordless
Drilling Speed 0 - 1,050 rpm
Impact Energy 2.0 joules
Impact Rate 0 - 4,675 /min
Max Drilling Concrete 22 mm
Max Drilling Metal 13 mm
Max Drilling Wood 26 mm
Nett Weight 2.6 kg excl.battery
Vibration Chiselling [Uncertainty K] 9.6 m/s [1.5 m/s]
Vibration Drilling Concrete [Uncertainty K] 14.7 m/s [1.5 m/s]
Warranty Bosch Professional 3 Year Warranty (Registration Required)
EAN Barcode 4053423323313
