The Bosch GCM 12 SDE professional dual bevel mitre saw guarantees precision and versatility. It offers a massive 120mm depth or 400mm maximum width of cut. The bevel and mitre cutting facility on both sides have indents at common angles. A laser line projects the cut line across your work-piece. Both sides of the table have pull out extensions to give extra support to longer workpieces. Variable speed control featured on the 230V option allows the cutting of a wider variety of materials. A well-designed dual dust extraction system helps keeps your working environment clean. The spindle lock combined with an SDS blade nut makes blade changes fast and tool-less. To achieve the maximum 400mm crosscut, a sacrificial base board is required. The integral carrying handle makes transportation easier and safer.
Bosch
Bosch GCM 12 SDE Dual Bevel Mitre Saw
| Bevel Angle Range | 47 - 0 - 47 |
| Dust Extraction | 35 mm Outlet |
| Mitre Angle Range | 52 - 0 - 60 |
| Overall L x W x H | 860 mm x 600 mm x 530 mm |
| Spindle Lock | Standard Feature |
| Blade Diameter | 305 mm |
| Sound Power Level LwA [Uncertainty K] | 105 dB(A) [3.0 dB] |
| Blade RPM | 3,100 - 4,000 rpm |
| Sound Pressure Level LpA [Uncertainty K] | 92 dB(A) [3.0 dB] |
| Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Motor Power | 1,800 W |
| Model | GCM 12 SDE |
| Bore Size | 30 mm |
| Electric Brake | Standard Feature |
| Max Bevel Cut @ 45º W x H | 360 mm x 60 mm |
| Max Compound Cut @ 45º W x H | 240 mm x 60 mm |
| Max Crosscut @ 0º W x H | 400 mm x 120 mm |
| Max Mitre Cut @ 45º W x H | 250 mm x 85 mm |
| Nett Weight | 28.6 kg |
| Voltage | 230 V |
| Warranty | Bosch Professional 3 Year Warranty (Registration Required) |
| Voltage | 230 V |
| EAN Barcode | 3165140769679 |
