The design of the Bosch GCM 8 SDE puts ease of use at the top of the list. All aspects are considered, whether its adjustments, scope of materials or your working environment. The GCM 8 SDE Professional is compact and portable, weighing just 18.5kg. Variable speed control from 3,500 to 5,000rpm, allows you to cut a wide variety of materials from wood to metal or plastics. The saw comes with an SDS blade-locking nut. Blade changes are quick and simple, without any additional tools. The ability to change the saw blade so easily, to suit different materials, means work becomes more efficient and your blades last longer. The saw will cut bevels up to 47, and has indents at 22.5, 30 and 45 for ease of setting. The positioning of the bevel-locking lever on the right-hand side next to the bevel scale, simplifies the operation. Dust extraction takes place from two points, one above the blade through the guard and a second directly behind the blade. Fitted to the saw arm with a long aperture, this second point efficiently captures the debris. A depth-stop allows you to cut trenches or tenons. The GCM 8 SDE mitre saw includes a laser-projected cutting line, transport handle and side extensions on the left and right to support longer workpieces. Power output: 1,600 W
Bosch
Bosch GCM 8 SDE 216mm Double Bevel Mitre Saw
| Bevel Angle Range | 47 - 0 - 47 |
| Mitre Angle Range | 52 - 0 - 60 |
| Overall L x W x H | 460 mm x 910 mm x 410 mm |
| Spindle Lock | Standard Feature |
| Blade Diameter | 216 mm |
| Sound Power Level LwA [Uncertainty K] | 108 dB(A) [3.0 dB] |
| Blade RPM | 3,500 - 5,000 rpm |
| Sound Pressure Level LpA [Uncertainty K] | 98 dB(A) [3.0 dB] |
| Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Motor Power | 1,600 W |
| Plug Fitted | UK 3 pin plug |
| Model | GCM 8 DCE |
| Bore Size | 30 mm |
| Max Bevel Cut @ 45º W x H | 312 mm x 45 mm |
| Max Compound Cut @ 45º W x H | 225 mm x 30 mm |
| Max Crosscut @ 0º W x H | 312 mm x 70 mm |
| Max Mitre Cut @ 45º W x H | 225 mm x 70 mm |
| Nett Weight | 18.5 kg |
| Voltage | 230 V |
| Warranty | Bosch Professional 3 Year Warranty (Registration Required) |
| EAN Barcode | 3165140654395 |
