Bosch PRO GDR 18V-215 Cordless Impact Driver delivers fast, efficient screwdriving performance in a compact, lightweight design. Fitted with a low maintenance brushless motor capable of driving long screws into timber and handling demanding fastening tasks in metal, it combines impressive power with excellent control, making it ideal for professional trade use.
Producing up to 215Nm of torque and a maximum no-load speed of 3,300rpm, the GDR 18V-215 is built for high productivity. Its compact cordless design makes it easy to work in confined spaces, while the 1/4 hex bit holder enables quick and convenient bit changes. Weighing just 1kg excluding battery, it remains comfortable to use throughout the working day.
Two Auto Driving Modes help deliver consistent results when working with wood and metal. Automatic Shut Down and Automatic Slow Down functions reduce the risk of overtightening, screw damage and material marking, helping to achieve a cleaner, more professional finish. With an impact rate of up to 3,800bpm, the tool drives fasteners quickly and efficiently into a wide range of materials.
Bosch Professional tools are engineered for demanding trade and site use, delivering the durability, performance and reliability professionals rely on every day.
Ideal for joiners, carpenters, fitters, builders and maintenance professionals, the GDR 18V-215 is suitable for driving wood screws, self-tapping screws, machine screws and general fastening applications.
Body only, not supplied with battery or charger.
Part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
Supplied with belt clip.
Battery Voltage 18 V
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 108 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 100 dB(A) [3.0 dB]
Model GDR18V-215
Impact Rate 0 - 3,800 /min
Impact Speed 0 - 2,100 rpm
Length [Front to Back]: 121 mm
Nett Weight 1 kg
Torque 215 Nm
Torque Settings 2
Vibration Fastening [Uncertainty K] 21.3 m/s [1.6 m/s]
Warranty Bosch Professional 3 Year Warranty (Registration Required)
EAN Barcode 4053423304961
