The GEX 18V-125 random orbit sander is the cordless answer to many sanding needs. From initial surface preparation, intermediate sanding, finish removal and final surface finishing this machine offers outstanding performance. This versatile sander performs particularly well working on large areas. The GEX 18V-125 Professional random orbit sander is a well designed machine. It has a lower profile, putting your hand closer to the work surface for outstanding balance and offering much improved control. The hand grip is ergonomic with a rubberised covering for comfort.
This is a machine built to last; with a maintenance-free brushless motor and an all-metal pad housing. Variable speed, along with constant electronic speed control results in an even surface every time. Hook and loop sanding pad means fast abrasive changes. Dust extraction is efficient, either into the dust bag supplied with the machine or preferably connected to a vacuum extractor.
The GEX 18V-125 Professional comes with a dust bag, a 125-mm sanding pad fitted with a hook-and-loop system. Part of Bosch 18V family of tools.
Part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
Supplied as body only (no battery or charger).
Battery Voltage 18 V
Dust Collection Dust Bag Supplied
No Load Speed 6,000 - 10,000 rpm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 74.5 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 63.5 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 1.9 m/s² [1.5 m/s²]
Manufacturer Part Number 601372201
Model GEX 18V-125
Nett Weight 1.05 kg (without battery)
Orbit Diameter 2.5 mm
Pad Size 125 mm
Warranty Bosch Professional 3 Year Warranty (Registration Required)
EAN Barcode 4059952539645
