The GKF 18V-8 Professional Palm Router is the flagship of 18V routing, delivering maximum power, precision, and accessory compatibility in a compact, expertly engineered design. Whether you're edge profiling or tackling demanding surface routing tasks, this router offers a best-in-class experience tailored to the needs of discerning woodworkers and professionals alike.
With the most compact height of any 18V palm router, the GKF 18V-8 ensures reduced top-heaviness and superior control, making it a joy to handle even in intricate applications. Its powerful brushless motor and fine depth adjustment allow for clean, accurate cuts, while the hands-free spindle lock simplifies bit changes for uninterrupted workflow. Purpose-built vacuum adaptors for both surface and edge routing set this tool apart, offering exceptional dust collection and a cleaner working environment.
Supplied as Body only (no batteries and charger included) with: 1 x Parallel Guide, 1 x Collet with Nut 1/4, 1 x Surface Routing Dust Extraction Adaptor, 1 x Edge Routing Dust Extraction Adaptor, 1 x Chip Shield 1 x Wrench 17mm. Compatible with all Bosch Professional 18V batteries, including ProCORE18V batteries and chargers, and is also part of the AMPShare multi-brand battery alliance, ensuring versatility and convenience on the job site.
Collets Supplied 2026-04-01 00:00:00 +0100
Overall L x W x H 95mm x 92mm x 168mm
Corded or Cordless Cordless
Cutter Speed 10,000 - 30,000 rpm
Model GKF 18V-8
Nett Weight 1.1kg (excluding battery)
EAN Barcode 4059952640792
