This oscillating Multi-tool is fitted with the high performance EC brushless motor. These motors are extremely energy efficient resulting in much longer battery run times (30% more than a standard DC motor). Brushless motors are maintenance-free, compact and lightweight.
The GOP 18 V-34 features the Starlock accessory mounting system. Starlock is a joint development by Bosch and Fein. This Snap-in system gives you quick, tool-free accessory changes, in less than 3 seconds. You can change blades contact-free, without the need to touch hot accessories. The system greatly improves the transmission of torque from the motor to the blade tip. No more wasted power, means faster working, minimised vibration and better results. The vibration control reduces vibrations to ensure smooth working and reduces fatigue. Additionally, the GOP 18 V-34 has improved battery positioning compared to previous models, with the battery on the side of the tool, allowing easy use.
The GOP 18 V-34 will take both standard Starlock and Starlock Plus accessories, giving you a wide range of cutting, sanding, grinding and polishing options. It can also cut PVC or metal, remove grout from tiles or for scraping off residues. The 3.4 oscillation enables you to work fast, while the variable speed control lets you tackle a wide variety of materials. The GOP 18 V-34 has a built-in LED light, illuminating the working area.
It features a slimmer body than the previous model, with a circumference of just 180mm to make sure you have control and maximum comfort when working.
Part of the multi-brand AMPShare battery system, offering flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPShare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
This is a body only tool, supplied without batteries or charger. Supplied with a Starlock Plus BIM Plunge Cut saw blade BIM 32mm with curve-Tec for wood and metal cutting.
Battery Voltage 18 V
Rating Trade/Professional
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 80 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 4.1 m/s² [1.5 m/s²]
Model GOP18V-34
Nett Weight 1.2 kg
Oscillation Rate 10,000 - 20,000 /min
Oscillation Stroke 2 x 1.7
Vibration Plunge Saw Blade [Uncertainty K] 3.9 m/s [1.5 m/s]
Vibration Segment Saw [Uncertainty K] 3.0 m/s [1.5 m/s]
Warranty Bosch Professional 3 Year Warranty (Registration Required)
EAN Barcode 4059952606835
