Bosch PRO GSB 18V-25 Cordless Impact Drill/Driver is a powerful and versatile cordless drill designed to tackle a wide range of drilling and fastening tasks. Combining screwdriving, drilling and impact drilling capabilities in one compact tool, it is equally at home working with wood, metal and masonry, making it an ideal choice for professional tradespeople and serious DIY users alike.
Delivering up to 60Nm of torque, the GSB 18V-25 features a two-speed gearbox with no-load speeds of 0-440rpm and 0-1,650rpm, providing the flexibility required for both controlled screwdriving and fast drilling. The impact drilling function enables drilling in masonry, while the 13mm keyless chuck allows quick and convenient bit changes. Electronic protection systems help prevent overload, overheating and over-discharge, extending both motor and battery life.
With a drilling capacity of up to 35mm in wood and 10mm in both masonry and metal, the GSB 18V-25 is a highly capable all-rounder for site, workshop and installation work. Weighing just 1.2kg excluding battery, it remains comfortable to use throughout the day, while the integrated work light improves visibility in poorly lit areas.
Bosch Professional tools are engineered for reliability, durability and performance, helping users work efficiently across a wide variety of applications.
Ideal for builders, joiners, electricians, plumbers and maintenance professionals, the GSB 18V-25 is well suited to drilling, impact drilling and fastening tasks.
Compatible with all Bosch Professional 18V batteries and chargers and part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
Supplied with 2 x GBA 18V 4.0Ah batteries and a GAL 18V-40 charger.
Battery Capacity 4.0 Ah
Battery Voltage 18 V
Rating Trade/Professional
Batteries Included 2
Corded or Cordless Cordless
Chuck Capacity 1.5 mm to 13 mm
Chuck Type keyless
Manufacturer Part Number 0 601 9K9 377
Length [Front to Back]: 207 mm
Max Drilling Masonry 10 mm
Max Drilling Metal 10 mm
Max Drilling Wood 35 mm
Nett Weight 1.2 kg excl. battery
Torque 60 Nm
Vibration Drilling Masonry [Uncertainty K] [1.5 m/s]
Vibration Drilling Metal [Uncertainty K] 1.5 m/s
Warranty Bosch Professional 3 Year Warranty (Registration Required)
EAN Barcode 4053423341263
