Robust and powerful with an all metal gearbox for durability, the GST150 will cut up to 150mm in depth. Fitted with a 4 stage pendulum, constant electronics as well as variable speed trigger and speed dial, you have full control whatever the material you are cutting. Giving high cutting precision with a saw blade clamp system, blade changing is fast with the Bosch SDS keyless lever system. The aluminium sole plate is robust and bend-resistant for the toughest jobs; a dust blower keeps the blade cut line free of sawdust. Fitted with a removable dust extraction port for connection to a vacuum. Supplied in case with 1 x T144DP wood blade, splinter guard, extraction set and glide shoe for sole plate.
Bosch
Bosch GST 150 BCE Jigsaw with Bow Handle
| Stroke Length | 26 mm |
| Sound Power Level LwA [Uncertainty K] | 94 dB(A) [3.0 dB] |
| Corded or Cordless | Corded |
| Sound Pressure Level LpA [Uncertainty K] | 83 dB(A) [3.0 dB] |
| Vibration Cutting Wood [Uncertainty K] | 7.0 m/s² [1.5 m/s²] |
| Motor Power | 780 W |
| Plug Fitted | UK 3 pin plug |
| Model | GST 150 BCE |
| Blower | Standard Feature |
| Max Depth of Cut Steel | 10 mm |
| Max Depth of Cut Wood | 150 mm |
| Nett Weight | 2.7 kg |
| Pendulum Action | Standard Feature |
| Stroke Rate | 500 - 3,100 /min |
| Tilting Base | Standard Feature |
| Vibration Cutting Sheet Metal [Uncertainty K] | 4.0 m/s [1.5 m/s] |
| Voltage | 230 V |
| Warranty | Bosch Professional 3 Year Warranty (Registration Required) |
| EAN Barcode | 3165140463638 |
