The Bosch GTS 635-216 table saw is a compact saw with large cutting capacities. The redesign of the motor/gearbox configuration maximises the cutting height from the 216mm blade. The result is a highly portable saw bench with a maximum depth of cut of 70mm and a cutting width of up to 635mm.
The extruded aluminium rip fence locks front and rear for precise, parallel rip cuts every time. Removing the face of the fence, laying it flat and re-attaching it forms a low fence for safe cutting of thin workpieces. The 1,600W motor provides all the power required to handle 70mm at full capacity.
Safety is paramount; the GTS 635-216 features a soft start, restart protection, a safety switch with emergency stop and efficient dust collection (when connected to a suitable vacuum extractor).
The machine is easy to transport with its ergonomic handles and low weight of 22kg. All the accessories can be stored on the machine; a place for everything and everything in its place, nothing gets lost. Its compact size makes it a good choice where space is limited, as it will fit neatly under a bench when not in use. For site work, a stand is available turning it into a useful saw bench with great capacities.
Supplied with TCT blade, mitre fence and push stick.
Blade Tilt 0 to 45
Max Depth of Cut @ 45º 50 mm
Max Depth of Cut @ 90º 70 mm
Max Width of Cut with Fence 635 mm
Overall L x W x H 658 mm x 500 mm x 332 mm
Power 1.6 kW
Rating Trade/Professional
Table Height 332 mm
Table Size 658 mm x 500 mm
Blade Diameter 216 mm
Sound Power Level LwA [Uncertainty K] 103 dB(A) [3.0 dB]
Blade RPM 5,500 rpm
Sound Pressure Level LpA [Uncertainty K] 94 dB(A) [3.0 dB]
Plug Fitted UK 3 pin plug
Model GTS 635-216
Bore Size 30 mm
Nett Weight 22 kg
Riving Knife Thickness 2.2 mm
Voltage 230 V
Warranty Bosch Professional 3 Year Warranty (Registration Required)
EAN Barcode 3165140975391
