Bosch PRO GWS 18V-8 Cordless Angle Grinder combines compact dimensions, low weight and impressive performance, making it an excellent choice for light-duty cutting and grinding tasks. Delivering the equivalent of 800W corded power, it offers the convenience of cordless working without compromising productivity.
Designed for comfort and control, the GWS 18V-8 features a slim, ergonomic grip and lightweight 1.6kg body (without battery), helping to reduce fatigue during prolonged use. The high-performance motor delivers a no-load speed of 11,000rpm, providing fast cutting performance in materials such as rebar, metal sheet, PVC and tiles, as well as deburring light metalwork. Optimised battery runtime allows you to complete more work between charges.
The grinder accepts 125mm and 115mm discs with a 22.23mm bore and features an M14 spindle thread for compatibility with a wide range of accessories. The metal flange is compatible with Bosch dust extraction attachments, helping to create a cleaner working environment when required.
Bosch Professional tools are engineered for trade and industrial use, offering the durability, performance and reliability professionals demand on site and in the workshop.
Ideal for fabricators, maintenance engineers, electricians, plumbers and general trade users, the GWS 18V-8 is perfect for light-duty cutting, grinding and finishing applications.
Body only, not supplied with battery or charger.
Part of the multi-brand AMPShare battery system, offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Fein and Bosch Professional 18V tools and chargers all the way back to 2008.
Supplied with backing flange, auxiliary handle, locking nut, two-hole spanner and protective guard.
Battery Voltage 18 V
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 99 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 91 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] <2.5 m/s² [1.5 m/s²]
Model GWS18V-8
Bore Size 22.23 mm
Disc Diameter 125 mm
Disc Speed 11,000 rpm
Nett Weight 1.6 kg
Spindle Thread M14
Vibration Grinding [Uncertainty K] 7.8 m/s [1.5 m/s]
Warranty Bosch Professional 3 Year Warranty (Registration Required)
EAN Barcode 4053423323573
