The Airmaster PTC Floor Standing Heater is made with a ceramic element for quick efficient heating. It has two heat settings (1,000W/2,000W) which can be switched off for use as a cooling fan during hot weather. Fitted with a comfortable carry handle for easy positioning/repositioning. Suitable for heating rooms/workspaces up to 30m³. Specifications:
Input Voltage: 240V (50Hz).
Output Rating: 1,000W/2,000W.
Dimensions: 190 x 215 x 158mm.
IP Rating: IP55.
Cable Length: 1.6m.
