Araldite
Araldite® RAPID Epoxy Resin - 24g Syringe
SKU: 340282
€8,95
  • Dispensing syringe, takes guesswork out of mixing quantities
  • Suitable for Wood, Metal, Plastics, Cloth, Leather, Rubber and Ceramics
  • Interior or exterior use, once stuck it stays stuck
  • Setting time 5 minutes - 3 hours N.B. To buy this product you must be aged 18 years or over.
Araldite is a two-part epoxy resin that, when mixed cures to produce an incredibly strong bond between many different types of materials. The adhesive should be mixed a little at a time in equal proportions, for convenience the syringe packs dispense equal amounts of adhesive at a time. Rapid Araldite can be moved for up to 5 minutes and requires at least 3 hours before the bond is totally set. Resin comes in easy to use 24g Syringe.
Setting Time 6-16 hours (Standard), 10 mins/16 hours (Rapid)
Suitable For Wood Metal Some Plastics Cloth Leather Rubber Ceramics Masonry Fibreglass
Adhesive Type Epoxy Resin
Size 24g
Curing Time Rapid Usage: Interior or Exterior Web Attribute Set: Resin Adhesives
EAN Barcode 7610594000077
