A packs 100mm diameter sanding discs to suit the Arbortech Power Carving Unit. The discs feature hook and loop backing for quick abrasive change, allowing you to reuse partially worn discs. Each pack contains 8 discs; choose from 60, 120, 180 or 240 grit.
Arbortech
Arbortech Abrasive Discs 100mm (Pkt 8)
| Abrasive Material | Aluminium Oxide |
| Abrasive Backing | Hook and loop |
| Abrasive Disc Diameter | 100 mm |
| Pack Quantity | 8 |
| Abrasive Grit | 60 |
| EAN Barcode | 9313478902433 |
