The Arbortech Contour Sander™ is solidly made, ingeniously designed and precision engineered.
It features an innovative design resulting in a true random orbit action that is only evident when the disc is applied to the work. It produces an excellent finish free of sanding marks and won't leave the friction burns that a spinning pad is prone to do. The sander is designed to fit the Arbortech Power Carving Unit or any 100 or 115mm portable angle grinder.
The Contour Sander™ is remarkably effective, rapidly abrading material to give a very good finish, even with the coarsest grades. Owing to the very flexible outer rim of the sanding disk, where most of the sanding takes place, it does an excellent job of sanding curved surfaces. In addition, the unique design means that vibration from the grinder is minimal.
Includes Contour Random Sander™ Attachment, rubber backing pad and sanding discs: 4x 40g, 4 x 80g, 4 x 120g, 4 x 180g, 4 x 240g, 4 x 400g
Additional Accessories No
Model SAN.FG.210
EAN Barcode 9313478615456
