These 50mm diameters, sanding discs extend the scope of the Arbortech Contour Sander, Arbortech Mini TURBO Plane Kit and the Mini Carver.
They are heavy-duty to withstand harsh conditions when power sanding. The cloth-backed abrasive, unaffected by heat generated during power sanding, has an exceptionally long life.
Supplied in packs of 20 discs of a single grit, ranging from coarse 60 grit to extra fine 320 grit.
Additional Accessories No
Pack Quantity 20
Abrasive Grit 320
Web Attribute Set Power Carvers
EAN Barcode 9313478020144
