One of the most useful cutters to have in your collection, the 45 chamfer cutters are excellent for just removing the sharp edges from your joinery work or making a wider more defined chamfer. Bearing guided cutters are an asset for curved work, as the cutter will follow the shape of the workpiece.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 11 mm (7/16")
D = Overall Diameter 30 mm (1.3/16")
K = Cutter Angle 45°
Web Attribute Set Chamfer, Engraving & V-Groove Router Cutters D: 30 X: 11
EAN Barcode 5052511030101
