This Axcaliber biscuit jointing blade is 100mm in diameter has 8 tungsten carbide teeth to produce an accurate biscuit slot. With a 22mm bore, this will fit almost all known biscuit jointers. A high quality blade for trade or professional use.
Axcaliber
Axcaliber Biscuit Jointer Blade
| Blade Diameter | 100 mm |
| Maximum RPM | 16,000 rpm |
| Diameter | 100mm Dia |
| Kerf | 4mm Kerf |
| Teeth | 8 Teeth |
| Web Attribute Set | Biscuit Jointer Blades |
| EAN Barcode | 5052511000708 |
