A large dovetail cutter, useful for cutting dovetail grooves. The 14 slope matches that of the UKJ Technology dovetailed T-track, when producing custom made jigs or router tables.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 22.2 mm (7/8")
D = Overall Diameter 22.2 mm (7/8")
K = Cutter Angle 14°
Web Attribute Set Dovetail Router Cutters D: 22.2 X: 22.2
EAN Barcode 5052511029037
