Edge Breaker router cutters round over sharp edges giving a very exact and controlled result. They are available in a choice of radii, all bearing guided for rounding straight or curved edges. These cutters remove the arris, leaving a perfect finish. If left as a sharp corner the wood may splinter or crumble. A sharp corner will not take a finish. You cannot paint a sharp edge. All cutters are 1/4 shank. PTFE coating minimises resin build-up. Available in 1mm or 2mm radius.
Shank Diameter 1/4" (6.35 mm)
D = Overall Diameter 20.5 mm (13/16")
R = Radius 1 mm
EAN Barcode 5052511123872
