Axcaliber router cutters for use with Leigh 'D' series and Leigh Superjigs. The cutters can also be used for sliding dovetails and carcase construction. Produced using advanced technology on up-to-the-minute multi axis CNC machinery. Shanks made from SAE4140 steel hardened to Rockwell 45 HRC, renowned for its hardness and strength. A finely ground edge ensures a durable efficient cutter and a thick PTFE coating reduces the build up of resin.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 31.75 mm (1.1/4")
D = Overall Diameter 12.7 mm (1/2")
Leigh Part No. 160 Web Attribute Set: Straight Router Cutters Router Cutter Type: Straight twin flute D: 12.7 X: 31.75
EAN Barcode 5052511048830
