Axminster Woodturning
Axminster Woodturning Ring & Centre Point Live Revolving Centre
SKU: 340138
€27,00
  • Eliminates the risk of splitting timber
  • Sealed dust proof bearings for long life
  • Tip exactly matches Ring Friction Drive
Unlike common pointed tailstock centres, a Live Ring Centre eliminates the risk of splitting small section or brittle timber. The tip has a small point to help with alignment when mounting your work. Support comes from the raised ring or rim. A Live Ring Centre leaves only a small mark on the end of the workpiece. The body features sealed dust proof bearings for a long life turning on the lathe. The dimensions of the ring and point exactly match those of the Axminster Woodturning Ring Friction Drive.
Made in Britain Yes
Morse Taper 1 MT
Intended Use Plays a crucial role in securely holding the workpiece on a lathe.
Web Attribute Set Live Tailstock Centres
EAN Barcode 5052511012824
