Perfect for small to medium woodworking projects
The Axminster Workshop AW1400B Bandsaw weighs in at 20kg, making it the smallest bandsaw in our Axminster Workshop range, and is packed with features not normally found on a saw of this size.
Buy with confidence
A red and white band saw with a black blade guard stands on a workshop floor next to a wooden workbench and a white jointer machine.
A space saving solution
The small, compact size allows you to save valuable floor space and can be easily stored or moved to one side when not in use.
Bearing guides
New and improved top and bottom bearing guided blade system provides improved accuracy and easy set up. The top guide has a height adjustment, allowing max 80mm depth of cut.
A person using a red and white Axminster Worksop band saw to cut a piece of light wood in a workshop setting with a wood-panelled wall background.
Increased cutting accuracy
Similar to the larger bandsaws in the Axminster Workshop range is the wide, curved steel chassis. This design gives you excellent tension on the blade to increase the cutting accuracy!
A close-up of a red and white Axminster Workshop band saw, with a person's hands adjusting the side knob against a wooden plank background.
Easy access
The keyless opening on the door means you can access inside your bandsaw with a simple twist of the knob.
A person using a red and white Workshop band saw to cut a light wood plank in a workshop setting with a blue dust collector hose connected.
Stable & robust
The bandsaw’s table is finely ground, solid cast iron and tilts from 1 to 45 degrees. This enables your work to glide effortlessly through the machine, allowing you to take on larger projects with peace of mind.
A close-up of a red and silver tabletop band saw with a light wood sheet being cut, and a mitre fence set on a light wood surface.
Optional mitre fence available
Made of cast alloy, the mitre fence allows you to produce accurate crosscuts at any angle. With clear markings and a slot for attaching a sacrificial fence, this is a very useful addition to the bandsaw.
A close-up of a bandsaw cutting a sheet of material over a wooden surface, with the AXCALIBER brand name and a British Made badge visible on the image.
Choose your blade
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
The Axminster Workshop AW1400B bench mounted bandsaw is designed for the small workshop and easily moved when not in use.
It features a strong welded steel chassis with a cast iron table. It will take blades from 4.8 to 9.5mm wide. Bearing blade guides and thrust bearing provide maximum blade control for improved accuracy over similar entry level bandsaws. The top guide blade has a rack and pinion height adjustment, giving a maximum of 80mm depth of cut.
It has a direct drive motor and balanced cast alloy wheels. The top wheel is mounted in a welded steel sub frame with blade tensioning and tracking controls conveniently close.
A single dust outlet port provides efficient dust removal when connected to a suitable vacuum extractor, which must be recommended for increased cutting performance.
The machine is supplied with a 6mm x 6tpi general purpose blade made from UK manufactured stock. A selection of different blades are available to suit many jobs.
An optional mitre fence is available to fit this bandsaw (sold separately).
This is a superb small bandsaw for a hobby or craft workshop or as an additional machine for smaller work.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 40 mm
Max Width of Cut with Fence 102 mm
Overall L x W x H 450 mm x 430 mm x 700 mm
Power 250 W
Rating Regular Use
T Slot Size 13 mm x 9mm
Table Height 290 mm
Table Size 300 mm x 300 mm
Table Tilt 0 - 45
Min Extraction Airflow Required 200 m³/hr
Sound Power Level LwA [Uncertainty K] 97 dB(A) [3.0 dB]
Sound Pressure Level LpA [Uncertainty K] 83.5 dB(A) [3.0 dB]
Web Attribute Set Bandsaws
EAN Barcode 5052511124886
