Axminster Workshop AW2260S Planer Thicknesser
The AW2260S is a substantial planer/thicknesser with spiral cutter block capacity. This machine would be at home in any home workshop or small trade workshop.
Buy with confidence
Spiral cutter block - AW2260S
Spiral Cutter Block
This cutter block features 24 knives arranged in two rows, lasts many times longer than HSS blades, and is noticeably quieter in use.
Single lift tables - AW2260S
Single Lift Tables
The tables are joined together and can be lifted in one motion, making it quicker to switch between jointing and thicknessing.
Digital height readout - AW2260S
Digital Height Readout
Quick and easy thickness adjustment ensures accurate cuts, every time.
1500W motor - AW2260S
1500W Motor
Ample power, yet still runs on a normal 13 amp plug.
Alloy fence - AW2260S
Alloy Fence
A tilting alloy fence with a sturdy cast iron support arm provides accuracy and durability.
Large capacity - AW2260S
Great Capacity
The AW2260S has a maximum cutting width of 250mm and height of 180mm, allowing you to tackle big home projects.
The AW2260S planer thicknesser with its spiral cutter block is a pleasure to use and delivers excellent results. The spiral cutting block has twenty four, four sided, solid carbide cutters arranged in a helix. The shear cutting action produces a silky smooth finish. There is a complete lack of planing ripple as often found using traditional straight knives. Each cutter’s edge will last around 10-20 times longer than a HSS knife and each cutter has four edges. When a cutter does become dull, take the torx driver supplied and turn the cutter through 90, retighten the screw and you're ready to go again. Down time is a bare minimum, no resetting or waiting for the blades to come back from the sharpening. Spiral cutter blocks are notably quieter in use and produce noticeably less vibration. Extraction is more efficient due to the size and even shape of the waste produced.
When surface planing, a long rigid alloy fence supports your work. The fence is easily adjustable with stops for 90 and 45. Changing from surfacing to thicknessing is very simple. You don’t need to remove or change the position of the fence when you lift the table. The single lift table mechanism works well, spring supported it requires little effort. There is a power feed engagement lever for use when thicknessing; the 4.8m/min feed speed ensures a smooth, even finish. The AW2260S is fitted with a digital thicknessing gauge, greatly simplifying depth adjustment.
Please note, this machine is fitted with a 1.5kW motor, allowing it to run from a standard domestic 13A socket without the need for a more costly 16A electrical supply installation. If you require an EU plug, please ensure you purchase 113776.
Dust Extraction Outlet 100 mm
Feed Speed 4.8 m/min
Knives TC Spur Cutters x 24
Overall L x W x H 1,120 mm x 970 mm x 1,020 mm
Power 1.5 kW
Rating Regular Use
Min Extraction Airflow Required 1,500 m³/hr
Sound Pressure Level LpA [Uncertainty K] 87 dB(A) [3.0 dB]
Plug Fitted UK 3 pin plug
Web Attribute Set Combined Planer Thicknessers
EAN Barcode 5052511127443
  • UK Mainland - £70
