This 3 piece kit enables you to produce a wide variation of different designs of wine bottle stopper using your favourite timber or alternative materials. Let your imagination run wild!
The Stopper’s spigot is threaded, half has an M8 thread, the other an 8mm coarse thread. To ensure a secure fixing use glue in an 8mm pre-drilled hole in your blank. We recommend using thick CA or epoxy glue for security.
To make turning the bottle stopper a little easier, we recommend using the Axminster bottle stopper arbor (code 212316 for 1MT or 212317 for 2MT).
Difficulty Beginner
Web Attribute Set Project Kits Pilot Diameter: 8 mm
EAN Barcode 5052511037711
