Bahco 59/S31 31 piece bit set. The quick-release magnetic bit holder ensures that the bit remains securely in the holder until the release is driven. It features a groove part in both sides of the black coated body for a better grip and a lock-in type system with forward function. Contains: 5 x 25mm Pozidriv Bits: PZ1, PZ2(x3) and PZ3. 5 x 25mm Phillips Bits: PH1, PH2(x3) and PH3. 2 x 25mm Grabber Phillips Bits: PH2G(x2). 11 x 25mm TORX Bits: TX10, TX15(3), TX20(x3), TX25(x2), TX27 and TX30. 3 x 25mm Slotted Bits: 3, 4.5 and 5.5mm. 4 x 25mm Hex Bits: 3, 4, 5 and 6mm. 1 x 25mm Magnetic Bit Holder.
Bahco
Bahco 59/S31B Bit Set, 31 Piece
| Web Attribute Set | Screwdriver Bits |
| EAN Barcode | 7314150325788 |
