With 31 screwdriver bits to choose from you’re bound to find the right bit for the job. To speed up your search the bits are colour coded for quick identification. These 1/4 hex, 25mm bits are S2 modified steel for longevity. The set includes a 1/4 hex magnetic, quick change bit holder. The robust plastic storage case features a transparent lit and a rear belt clip.
The bit sizes as follows:
Phillips: Ph1 x 1, Ph2 x 2, Ph3 x 1
Pozidriv: Pz1 x 1, Pz2 x 2, Pz3 x 1
Slotted: 3mm x 1, 4mm x 1, 5mm x 1, 6mm x 1
Torx: T10 x 1, T15 x 1, T20 x 2, T25 x 1, T30 x 1, T40 x 1
Security Torx: TH10 x 1, TH20 x 2, TH25 x 1, TH27 x 1, TH30 x 1, TH40 x 1
Hex: 3mm x 1, 4mm x 1, 5mm x 1, 6mm x 1
Web Attribute Set Screwdriver Bits
EAN Barcode 3165140761734
