Bosch guide rails available in 2 lengths: 800mm or 1,600mm. Fittings directly to Bosch GKT 55 GCE plunge saw and to Bosch routers with a router adaptor. Fitted with a splinter guard that is cut perfectly with the saw blade on the first cut, the anti-slip strip on the underside of the rail can eliminate the need to clamp on some materials. Clamps and other rail accessories also available.
Please note: plastic end caps are no longer supplied with the rails.
Web Attribute Set Circular Saw Accessories Globale Group: low-margin-eu
EAN Barcode 3165140608152
