Robust and powerful with an all metal gearbox for durability, the GST150 will cut up to 150mm in depth. Fitted with a 4 stage pendulum, constant electronics as well as variable speed trigger and speed dial, you have full control whatever the material you are cutting. Giving high cutting precision with a saw blade clamp system, blade changing is fast with the Bosch SDS keyless lever system. The aluminium sole plate is robust and bend-resistant for the toughest jobs; a dust blower keeps the blade cut line free of sawdust. Fitted with a removable dust extraction port for connection to a vacuum. Supplied in case with 1 x T144DP wood blade, splinter guard, extraction set and glide shoe for sole plate.
Rating Trade/Professional
Stroke Length 26 mm
Sound Power Level LwA [Uncertainty K] 94 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 83 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 7.0 m/s² [1.5 m/s²]
Motor Power 780 W
Plug Fitted UK 3 pin plug
Web Attribute Set Jigsaws
EAN Barcode 3165140463638
