More than just a stable work stand, this table saw stand will also solve the problems of transport and storage. Making easy work of moving and storing your saw, it can be set up with the saw in one simple action and be ready for use in seconds. Bosch have patented their folding 'Gravity rise' system to allow one step set up action; the whole design is based around easy use. Designed to fit the Bosch GTS10 table saw we can see no reason why other similar saws could not be adapted to fit as well. Heavy duty steel construction, easily levelled on uneven and rough ground by 2 adjustable feet, the 8" pneumatic tyres are able to ride over bumps taking the strain and give good grip especially on uneven ground. Balanced when moving, simple to set up and stable in use, this stand is a sure must for your table saw.
Bosch
Bosch GTA 60 W Table Saw Stand
| Overall L x W x H | Length: 1,220 mm, Height: 622 mm |
| Web Attribute Set | Saw Bench Accessories Globale Group: low-margin-eu |
| EAN Barcode | 3165140526098 |
