The Easy Wood Tools Pro Easy Finisher™ is a carbide woodturning tool designed for making coves, smoothing hollows, refining sweeping curves, and producing clean final shapes on large bowls, oversized platters, long spindles, table legs, and other substantial turning projects.
As part of the largest, most substantial range in the Easy Wood line up, the Pro Easy Finisher™ provides maximum leverage and reach, making it ideal for finishing work on big, heavy workpieces.
Featuring a replaceable round carbide cutter and a robust 12.7mm square section bar, the Pro Easy Finisher™ sits flat and stable on your tool rest, offering smooth, predictable control with no sharpening required.
Its extra‑long 508mm American Hickory handle is engineered for power, leverage, and reduced fatigue, allowing turners to refine wide curves and deep hollows on large forms with confidence and comfort—even during long turning sessions.
The Pro Easy Finisher™ is engineered to deliver smooth, flowing finishing cuts across large surfaces. It excels at refining hollow forms, blending contours, shaping the interiors of wide bowls, and smoothing exterior curves before sanding.
Held parallel to the floor at centre height, the square bar ensures exceptional stability on the tool rest, helping to minimise catches and snatches even when working on heavy, dense, or oversized blanks.
Its mass and reach make it ideal for turning situations where control and balance are essential for producing clean, consistent finishing cuts.
With no sharpening required, simply rotate the cutter to a fresh edge when dull.
Easy Wood Tools’ premium solid carbide lasts many times longer than HSS and performs reliably on dry or green wood, acrylics, and resin.
What you get
Round carbide cutter fitted as standard
Hex key for easy cutter rotation or replacement
508mm American Hickory handle with copper ferrule for strength
12.7mm square section bar for maximum stability
Colour‑coded handle for fast range identification
Shaft engraved with the carbide cutter reference number
Specifications
Overall length: 724mm
Handle length: 508mm
Bar profile: 12.7mm square
Optional upgrade
Negative rake carbide cutters are available separately and perform exceptionally well on acrylics, polyester, and resin, producing a smoother, cleaner finish on timber—especially valuable during fine shaping and final cuts.
Replacement Tip Ci0 (109258)
