The Einhell TE-AP 18/13 Li-Solo Power X-Change All Purpose Saw is a particularly lightweight and handy saw for uncomplicated use - irrespective of whether in the home or garden. Due to its low weight and ergonomic, compact design, the reciprocating saw is also suitable for one-handed operation. Thanks to special soft-grip surface area, it lies securely in your hand.
It can be optimally adapted to different materials and the respective application using speed electronics. The saw blade can be exchanged quickly and without tools and inserted into the 0.6-1.6mm saw blade holder. For optimal use of the saw blade, the saw shoe can be adjusted exactly using the hexagon socket wrench which is stored and supplied in the housing. The switch-on lock and the soft start, which additionally protects the saw motor, increase user safety.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Powered by Lithium-ion rechargeable batteries with a battery management system for a long life.
Supplied as body only (no battery or charger).
Specifications:
Strokes at No Load: 3,000/min.
Stroke Length: 13mm.
Capacity: Wood 50mm, Steel 4mm.
Weight: 1.13kg.
