The Faithfull Quick Dowelling Jig is designed to produce fast, accurate dowel joints in most types of timber and many man‑made boards. Easy to use and highly precise, it enables the creation of strong, professional‑quality joints using a standard power drill.
Compatible with 6, 8 and 10mm dowels, the jig can be used to form; edge to edge joints, corner L joints, T‑joints and mitre joints, making it ideal for a wide range of furniture and cabinetmaking tasks. The set includes a dowelling jig, angle piece and clear instructions to help achieve consistent results.
Board thickness; 6mm dowel 12 - 14mm, 8mm 15-17mm and 10mm 17 - 23mm.
Web Attribute Set Dowelling Jigs & Accessories
EAN Barcode 5023969306384
