The Faithfull 4 Piece 1/4 Drive Multi-Function Cutter Set is a versatile accessory kit designed for a variety of drilling, cutting, shaping and finishing applications. The set includes a 6mm rotary rasp for shaping and enlarging holes, a 4-12mm step drill for creating accurately sized holes, an 8-20mm taper drill for progressively enlarging holes, and a 12.4mm countersink for producing clean, recessed screw holes. Each tool is fitted with a 1/4 drive shank for compatibility with suitable drills and drivers. Supplied in a durable metal storage case, this compact set provides a practical solution for workshop, trade and DIY use. The set covers a size range of 4-20mm.
Web Attribute Set Miscellaneous Boring Bits
EAN Barcode 5023969254470
