Be prepared, when it comes to putting things together, there’s bound to be an answer in this 104 piece assembly kit. Whatever the job throws at you help lies within this Systainer organiser. This kit is the ideal companion to any of the Festool cordless tools with the FastFix feature.
Contents comprise:
5 of each 1/4 hex, 25mm screwdriver bits; PZ3, PZ2, PZ1, PH1, PH2, PH3, TX15, TX20, TX25, TX30, 5.5 slotted &, 6.5 slotted
1 each 1/4 hex CENTROTEC, 100mm screwdriver bits: PZ1, PZ2, PZ3, PH1, PH2, PH3, TX15, TX20, TX25, TX30, 5.5mm & 6.5mm slotted.
1 each 1/4 hex CENTROTEC wood drill bits with centre point for quick, clean holes: 4mm, 5mm, 6mm, 8mm & 10mm.
1 each 1/4 hex CENTROTEC deburring countersinks 2-8mm,& 5-15mm
1 x 1/4 Hex CENTROTEC magnetic bit holder 60mm
1 x 1/4 Hex CENTROTEC magnetic bit holder 120mm
1 x 1/4 hex CENTROTEC 5mm TCT drill with depth stop
1 x 1/4 hex CENTROTEC 3.5mm HSS drill with depth stop
1 x 1/4 hex CENTROTEC 5mm hinge centring bit
1 x 1/4 hex CENTROTEC hook driver
1 x bit box (twinBOX BB-MIX)
1 x drill bit case (BKS D3-8 CE/W-K)
1 x 1/4 CENTROTEC quick change bit holder (BHS 60 CE)
1 x CENTROTEC fast change tool chuck with fast fix interface (WH-CE)
1 x 1/4 hex CENTROTEC screwdriver handle (SD-CE-DRIVE-UNI)
1 x Systainer SYS3 ORG M 89
Manufacturer Part Number 576804
Web Attribute Set Festool Centrotec
EAN Barcode 4014549381397
