This pack of five assorted sabre saw blades will cover most of your general requirements, ensuring you’re equipped and ready whatever the job. The pack contains a bi-metal metal cutting blade and a 305mm long fast, rough cutting wood blade, along with three bi-metal wood cutting blades general use and where there is a possibility of encountering metal embedded within the wood.. All blades feature the universal shank fitting, suitable for use in the majority of sabre saws.
Contents:
2 x Bi-metal, universal wood/wood with metal 230mm x 4.3mm pitch
1 x Bi-metal, universal wood/wood with metal 305mm x 4.3mm pitch
1 x Fast cutting wood blade 305mm x 5mm pitch
1 x Bi-metal metal cutting blade 230mm x 1.6mm pitch
Manufacturer Part Number 577496
EAN Barcode 4014549412879
