This DOMINO KV-SYS-D8 connector system allows you to produce highly accurate and strong knockdown joinery simply and quickly.
The joints are easy to assemble, disassemble and reassemble. All joints are simple and quick to machine using the DOMINO DF 500 jointer; the only additional tool needed is a drill with which to bore a single hole for the tightening the connector. The joints are strong, tight and unobtrusive with a neat cover cap the only clue to its existence.
The system offers increased flexibility for a wide range of applications. It will produce panels with corner ‘L’ joints, centre ‘T’ joints or centre panel joints through a panel and joints between a series of holes. The system makes it significantly easier to assemble a piece of furniture, even working alone. The DOMINO KV-SYS-D8 is suitable for materials with a thickness between 18mm and 28mm.
The DOMINO DF 500 Connector Assortment Systainer offers the best value to get you started with the system.
Supplied in a SYS 1 T-LOC Systainer containing:
70 x DOMINO/DOMINO KV D8 basic structure connector
20 x DOMINO/LR32 KV-LR32 D8 basic structure connector
10 x DOMINO/DOMINO MSV D8 centre panel connector
10 x DOMINO/LR32 MSV-LR32 D8 centre panel connector
50 x Dark brown cover caps
50 x Silver cover caps
50 x White cover caps
50 x Grey cover caps
20 x DOMINO D 8 x 36 mm
1 x BS-KV D15 drill template, 203164
1 x KVB-HW D15 CE hinge location cutter, 203165
1 x Screwdriver
The Festool wooden dowels included are certified by the Pan European Forest Council (PEFC)
Manufacturer Part Number 203170
Web Attribute Set Dowelling Jointers Accessories
EAN Barcode 4014549302781
