The MFT/3 work table from Festool is part of a comprehensive range of products providing the end user with quality, versatility and, in this case, a superb work holding device. It truly is a multifunction table with many different holding, cutting and machining operations possible. The MDF top is perforated over its entire surface with 20mm holes to take the accessory clamps. These can be adapted to take regular and irregular shaped workpieces up to 78mm thick and 700mm wide. The supplied guide rail and angle stop will provide the opportunity for many different cutting and machining variations when using a portable circular saw or router.
Festool
Festool MFT/3 Multifunctional Table with Accessories
| Overall L x W x H | 1,102 mm x 718 mm x 900 mm |
| Manufacturer Part Number | 495315 |
| Web Attribute Set | Festool CMS Moduler System and MFT Table |
| EAN Barcode | 4014549096420 |
