The patented Multi-Jetstream2 pad guarantees outstanding sanding results thanks to its unique design.
Multi-Jetstream2 pads guarantees virtually 100% dust extraction for a consistently high material removal rate. These 150mm diameter Multi-Jetstream2 pads fit the Festool RO 150 FEQ-Plus Rotex sanders. They feature StickFix hook and loop system allowing quick and easy changing of abrasive discs.
The pads are available in hard and soft for general sanding, and an ultra soft version designed for sanding rounded and contoured surfaces. Supplied as a single pad only.
Additional Accessories No
Manufacturer Part Number 202463
Web Attribute Set Dual Action Sander Accessories
EAN Barcode 4014549284674
