Features include enormous cutter depth range of 80mm, quick height adjustment and an exact fine adjuster in 1/10mm steps with a zero function. Fine adjuster can also be locked to the base allowing easy base adjustment to the cutter. Once set the lock on the handle clamps to both columns simultaneously for total accuracy. The innovative dust extraction system ensures that a very high level of waste is removed with a combination of extraction ring, chip catcher and exhaust adaptor. The extraction ring is cleverly controlled from the handle to allow you to view the cutter for position, then lowered for extraction. The spindle lock has a rocker and ratchet system for fast cutter changing and the base can be changed without tools. When used with a guide fence or a guide rail the rods are offset at 30 to the machine for safer, easier, guiding and working.
Supplied with 1/2 and 1/4collet, 30mm guide bush, chip deflector and spanner in a Festool SYS M337 SYSTAINER® storage case.
Also available to purchase with OF 2200 Accessory Set (produce code 702452) as a full package (product code 719998).
Collets Supplied 1/4 and 1/2
Rating Trade/Professional
Spindle Lock Standard Feature
Sound Power Level LwA [Uncertainty K] 98 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 87 dB(A) [3.0 dB]
Motor Power 2,200 W
Cutter Speed 10,000 - 22,000 rpm
Manufacturer Part Number 574353
Voltage 230 V
Web Attribute Set Routers
EAN Barcode 4014549151327
