All the items contained within the Systainer 3 will help you realise the full potential of your Festool guide rail. Everything that can make using the guide rail even better is here, organised in one Systainer 3: An Angle Stop, Kickback Stop, Guide Rail Connectors, Deflector and Guide Rail Clamps.
The Angle stop attaches quickly and securely without tools to your guide rail, allowing precise cuts of angles from -60 to +60.
Increased safety with the Kickback Stop. It functions as a limit stop or secures the circular saw against kickbacks when plunging into the workpiece.
Get connected, the guide rail connectors join and align two guide rails perfectly, as if they were one single piece.
The Deflector clips onto the end of your rail and prevents the vacuum hose and cable from snagging on the end of the rail.
The Guide Rail Clamps are designed to slide into the groove on the underside of the guide rail and secure the rail without causing an obstruction.
Smart accessories make working with the guide rail even easier and more efficient.
Overall L x W x H 396 mm x 296 mm x 137 mm
Rating Trade/Professional
Manufacturer Part Number 577157
EAN Barcode 4014549399699
