The latest generation of SYS3 M137 cases enable you to be better organised, more mobile and work with greater efficiency. SYS3 M137 is a complete and highly practical storage/transport system. Developed in conjunction with TANOS and bott; SYS3 M137 is the perfect answer to safe storage and easy transportation. Precision made for durability and reliability these cases are of the highest quality. They offer simple handling, high functionality and robustness. Be it in the workshop, on site or part of a mobile system in a vehicle, these cases provide the solution.
The cases lock together using the T-LOC central controller, they close, open and connect using a single movement. SYS3 M137 cases connect with one another and are fully compatible with all previous Systainer generations, mobile dust extractors and many other system accessories.
Fitted with front swing handles, SYS3 M137 cases are ideal for transporting in vehicles and make it easy to remove the SYS3 M137 from a shelf system. The front carrying handle allows you to carry smaller cases close to the body.
Overall L x W x H 396 mm x 296 mm x 137 mm
Manufacturer Part Number 204841
Web Attribute Set Power Tool Cases
EAN Barcode 4014549354872
