FISCH have produced a fast clearing premium drill bit made from high grade M2 steel. The unique four flute design with a brad point (lip and spur) tip ensures fast and easy cutting of the wood before the hole is drilled. The perfect drilling geometry not only makes holes more accurate, but also means holes can be drilled faster saving you time and, if a tradesman, money. They can be used in all types of wood, laminated boards, MDF and acrylic glass.
Due to the drill bit geometry and chip removal these drill bits have a consistent temperature behaviour, very clean chip removal and spurs that scribe the perfect hole, smooth drilling and give excellent performance without overheating.
Made in Austria. Supplied in a clear, plastic storage tube for protection and easy access.
Drill Bit Diameter 4.0 mm
Overall Length \ Working Length 75 mm 43 mm
L1 43mm L2: 75mm Web Attribute Set: Wood Boring Bits
EAN Barcode 9002696176565
