The Fiskars Xsharp™ Axe and Knife Sharpener acts as two sharpeners in one. The ceramic grind stone has clearly indicated cutting grooves for either axes or knives. The sharpener has an optimised sharpening angle for Fiskars blades with an easy-to-use mechanism. It is compact in size for convenient portability. Length: 165mm.
Fiskars
Fiskars Xsharp™ Axe & Knife Sharpener
| Web Attribute Set | Blade Sharpeners |
| EAN Barcode | 6411501207401 |
