Hermes self adhesive discs with a peel off backing.
The aluminium oxide abrasive on a flexible, adaptable paper backing has an open structure with antistatic properties to reduce clogging. VC152 is especially suited to sanding hard and soft woods as well as lacquer. It's perfect for initial, intermediate and fine sanding wood preparation and results in a good quality finish. It is also suitable for use on metal. VC152 is an excellent multi-purpose abrasive for use with powered sanders.
Available in a variety of grits. Sold in singles.
Please note, these discs can be re-used, by simply warming the disc with a hot air gun before gently removing, then protecting the glue surface with the peel-off backing.
These discs were formally BW 100 discs.
Abrasive Type VC 152 SK
Abrasive Backing Paper self-adhesive
Pack Quantity 10
Abrasive Grit 120
Abrasive Disc Diameter 150 mm
EAN Barcode 4050806701386
